HT4100 Vacuum System Diagram
Started by Jesse De La Vega, March 17, 2007, 10:20:31 PM
Jesse De La Vega
Anyone out there have a diagram of the vacuum hose routing for an HT4100 Engine in a 82 Eldorado? Thanks.
TJ H 20664
I had an 83 manual around somewhere but cant seem to locate it at the moment.   Check your local or nearest larger city library (if you are in the USA), they often have car manuals and you can copy what you need for the price of the copy.  Many also have an online subscription for services like ALL DATA but you usually have to ask someone how to get on.
Good Luck!
TJ H
20664
StPaul/Mpls MN USA
Gaylord Goclan
Hi I run a repair shop, and use Mitchells,  I should have the vacumn schmatics . If you have a fax,or send me your address and Ill send via snail mail.  Gaylord
Jesse De La Vega
Thanks Gaylord, Really appreciate your response. You can Fax to 310-443-6405 Attn:J. De La Vega. Thanks Again. Ill let you know when I receive it.
