U bolts
Started by William Medlock, June 13, 2007, 08:42:10 PM
William Medlock
Anyone have a contact for leaf spring u bolts for a 1940 Lasalle. I've searched some on the net but I haven't had any luck matching all the dimensions. Thanks for any help
Bill Ingler #7799
http://www.espo.com/    Try this link. Called Srings and Things
William Medlock
Thanks Bill, I'll check it out
harvey b
you might try to find a spring repair shop,they can make up u bolts any size,i used to work in a body shop that did spring work.all the u bolts came in straight lenths we just used to bend them to fit.call a truck repair shop and see if they have a contact for one.  thanks Harvey Bowness
Harvey Bowness
