35 Caddy headlight assy question
Started by steve benson, January 04, 2008, 04:48:33 PM
steve benson
35 Caddy;  Converting sealed beams back to original on my 35 coupe. I cant figure how it goes together or if I am missing some parts . I have orig reflectors, lenses and bezel . Seems like something is missing....need some advice.
Kerry
Hi, I'm not sure if your headlites are similar to my 39 LaSalles but the lay out should be; hd lite pod, then an interior bucket that has up and down and side to side adjustment, then a gasket, lens, and finally headlite rings. It sounds like your missing the interior buckets. If you get the Self Starter look in the back and look up Bruce Berghoff, he might have what your looking for. Hope this helps you. Kerry
