GE #4012 A 6-8v 35w 5.5" wide yellow fog light correct application ?
Started by Jeff Maltby 4194, August 17, 2008, 05:11:11 PM
Jeff Maltby 4194
My early 50's United Service Motors lists Guide bulbs only. What year/model Cadillac might these fit ?
Thanks in advance.
Jeffo 49er chapter :<)
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Bill Ingler #7799
Hi Jeff: Looking through my GE reference on bulbs I do not find that bulb being used on Cadillac. As you know the Cadillac fog lamps through 1952 used a 6 volt bulb # 1022 and this was a pre-focused dual filament bulb, for turn as well as fog. I could not find the 4012 6 volt bulb being used as factory equipment on any make car or truck. If I were to guess I would say the bulb was used in fog lamps of the type that were add ons for mounting on the front splash pans or bumper brackets.
