Where is the Neutral Safety Switch located on a 1949 Cadillac Series 62?
Started by Terryg57, October 16, 2008, 11:21:20 PM
Terryg57
 Can't locate the Neutral Safety Switch, any help wold be appreciated.  Just rewired the entire car, removed all the old wires, I should  of traced them, lesson learned.
Terry  ;)
Warren Rauch
I found a picture in a parts book. The switch is near the bottom end of the steering column jacket. But since the picture isn't in the car, I can't tell you weather to look under the hood or the dash! Warren
Philippe M. Ruel
Image below is for 1946-48, and typical for 1942 and 1949-52. Safety switch is part #20.2195, it looks to be under front floor.
1952 60 Special in France.
terryg
Quote from: Philippe M. Ruel on October 18, 2008, 02:19:09 AM
Thank you!!!!
