'65-'66 Automatic Level Ride Suspension
Started by Chris Conklin, March 05, 2009, 05:50:13 PM
Chris Conklin
Just a general question/concern about this feature, not currently having any issues. Any problems that are endemic to this option? I'm guessing that over time there could be leaks in the system, are there replacement parts or shocks available, etc.? Thanks for any education you can provide.
Chris Conklin
homeonprunehill
03-05-09
Chris, not to worry. On the other hand, nothing I ever worried about happen. Chris, it is MHO that some day you will need to replace something. I you see something in your travels and you thank you may need it someday, go ahead and buy it, You may never need it, but it is better to have it available then not. Good Luck,Jim
Jim Govoni CLC 20546
Yours would be the first 65-66 I would have seen working. Mine was removed and it's a manual fill from a valve in the trunk now.  Jim
1953 Series 62
1966 Fleetwood
1969 deVille Convert.
1941 Series 63
I keep the ALC in my 68 ELDO running even after 300,000 miles.  It takes a source of parts an occasional cleaning the compressor.
