Hydramatic shifts hard in third
Started by Eric August, March 18, 2009, 09:58:58 PM
Rusty Shepherd CLC 6397
While we're on the subject of Hydra-Matics, does anyone know why it took until 1956 for Hydra-Matic to have a Park position?  Dynaflow had it from its introduction for '48 and Powerglide when it came out for '50, so GM knew how to do it.  Only Chrysler Corp. was (a lot) later in providing a Park position, but then again it took them until mid '53-'55 to get rid of the clutch pedals in all their "automatic" cars.
Quote from: Rusty Shepherd CLC 6397 on March 22, 2009, 06:34:24 PM
To your first question: no, I don't know why Rolls stayed with the first generation of Hydramatic.
To your second question: when the lever is put in "R" and engine off, there is a mechanical "Park" , at least on the later versions. Probably the changes needed to have that position with the gear lever were too consequent.
Roger
