Exhaust manifold insulation source for WW II era flatheads?
Started by John Barry [CLC17027], May 19, 2009, 12:59:08 PM
What is/are the recommended source(s) for "correct" insulation for exhaust manifolds for the flathead V-8 engines of the '39-'48 vintage?  I had heard that it was McVey, but a recent check of their website showed nothing along those lines.  (I suppose I could get some sort of high temperature insulation from a plumbing/heating supply house, but it may not be the correct color, and it sure won't have the right bands to hold it in place.)  Thanks.
John Barry (CLC 17027)
Now-retired editor/Publisher of the Valley Forge Region newsletter, The Goddess
1940 La Salle series 50 four door sedan
Herman clc 19416
Try Bob Cooper @ Coopers Vinatge Cadillacs in Burbank.. (coopersvintageemail addresses not permitted) he has a very good replacement that comes with the straps and looks completely originsl.  The kit comes in aplastic bag that is a flast sheet that you wrap around the pipe and when exposed to air shrinks to the pipe..almost like casting a broken arm  great stuff
Bill Ingler #7799
Hi John: Coopers has that listed as a kit for $90. If you do buy it I recommend that if possible to disconnect the exhaust pipe from the manifold and muffler. It is a lot easier working with exhaust pipe out of the car. The last two that I have put on required about an inch of material being cut after the material is wrapped around the pipe. With the pipe on the car then you will need to find a way to hold everything in place while you fit, cut and put the straps in place.  Have fun
http://www.coopersvintage.com/catalogs.html
Otto Skorzeny
Call McVey's whenever you need something. Their website sucks. They have many things that are not on the website the last time I looked.
fward
HUGE VENDOR LIST CLICK HERE
Quote from: Herman clc 19416 on May 19, 2009, 01:43:59 PM
Quote from: Bill Ingler #7799 on May 19, 2009, 01:44:08 PM
Thanks for the installation description and tips, along with the pricing.  Bill: you're the second person to mention removing the exhaust pipe.  I'd guess Coopers also has the necessary gaskets that I'd need to replace after removing the exhaust pipe.
Quote from: ottoskorzeny on May 19, 2009, 05:55:43 PM
Tell me how you really feel!  ;D  By the way, I like the fact that you've named your '56 after der Eisenreichskanzler.
Otto Skorzeny
Quote from: John Barry [CLC17027] on May 20, 2009, 07:11:26 AM
Only indirectly. It's big and grey so it's named for the battleship which, in turn, was named for Otto Von Bismarck.
fward
Jeff Maltby 4194
Here's my oem 49 coupe pipe wrapping. Note the undercoating on rear band.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Cadcliff
Cliff Graubard
CLC #1430
1955 Cadillac Broadmoor Wagon x3
1956 Cadillac Broadmoor Wagon- One of two
1955 Eldorado- bronze
1961 Cadillac Biarritz-bucket seats
1964 CDV- Silver/Red Every option
1960 Cadillac Eldorado Biarritz
1940 and 1941 60S
1961 Cadillac Convertible
1965 Cadillac Convertible
Don Pettee
Don Pettee CLC #20471
