Door handle rermoval on a 39 60S
Started by kgarretty, May 29, 2009, 07:26:49 PM
kgarretty
Does anyone know to remove the exterior door handles from a 39 Cadillac 60S?  I don't see ant pins or screws-
Warren Rauch
  Open the door. From the end ,you should see a small round hole opposite the door handle. If you rotate the outside handle and watch the screw should come into view.You  may have to make a special screw driver to get thru the hole to it. Warren
kgarretty
CLC#12231
When you loosen and remove the screw be careful that you don't drop it down inside the door.  It is a special tapered screw and they are hard to find.
Frank
kgarretty
