Coils: does ground polarity matter?
Started by John Barry [CLC17027], July 22, 2009, 12:28:29 PM
I'm looking to replace the existing coil in my '40 LaSalle (naturally we're talking a 6V positive ground system).  I believe that the nature of the ground (positive vs. negative) doesn't matter with respect to the coil--but could someone please confirm/correct this?  Thanks.
John Barry (CLC 17027)
Now-retired editor/Publisher of the Valley Forge Region newsletter, The Goddess
1940 La Salle series 50 four door sedan
Yes polarity on any coil is critical, you can loose about 25% of the maximum out put.
