57 cadillac deville vin location
Started by Connie, July 16, 2009, 08:58:25 PM
Connie
Can someone tell me where the vin is located on a 57 cadillac deville?
Connie
kelly
If the car has the original engine in it, look at the front right (passenger side) engine boss, where the head and block come together. The vin is stamped onto a flat area at the head to block joint, on the block. I believe you can also find it on the frame rail on the same side, outboard.
Kelly Martin
Kelly Martin
1957 Fleetwood 75
Connie
Thanks for the help. I'll look there.
Connie
John Morris #23947
Also, there should be a plastic tag on the door jamb, with same number as stamped on engine.
71 Olds 98 LS, 66 Fairlane 500 XL Convertible, 55 Packard Clipper Super, 58 Edsel Ranger, 72 Cheyenne Super, many 49-60 parts cars, abandoned "House Of Doom" full of 49-60 parts. Huge piles of engine parts, brackets, tin, Hydramatic & Jetaway parts,  thousands of stainless moldings, dozens of perfect sedan doors.
customcars
there is a vin on the frame on the pass side, you will may need a mirror just in board of the door....yes on the block (if it is the original engine) ....the plastic oil change door tag , and on the cowl blister behind the brake booster.....the most reliable is the frame.....k
