oil pan pick up on 365 eng loose ? help !
Started by paul57, September 02, 2009, 11:38:51 AM
paul57
can anyone tell me if the oil pick up filter in the sump is supposed to be loose and move up & down ? or is it designed to be a loose fit and go up and down with the level of oil ??? investigating a knocking which sounded like a big end ..  have never seen this before they have always been a solid pipe . just wondered if thats the cause ?
anything else to look out for while i've got the sump dropped ?
but its what i've always wanted and this time its a keeper , honest !
1957 cadillac eldorado seville . turning fuel into vapours ...
pmurphy
Walter Youshock
It is supposed to float, thereby picking up the clean oil from the top.  It should move only about an inch or so up and down.
Remember, these cars had a limited-flow filter.  All the crap sunk to the bottom of the pan.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
