1961 Cadillac Hesitation Blues
Started by Jack Miller CLC# 24441, September 26, 2009, 11:05:06 AM
Otto Skorzeny
Hi Jack,
On a 50 year old car, the factory specs are a good place to start but they aren't always applicable today. Gasoline isn't the same as it was 50 years ago nor is the engine. Even a rebuilt engine is going to differ - even if only slightly - from the specs laid down by the factory when it was new.
All of this combines to make it necessary to alter the tune up specs on the engine.
fward
HUGE VENDOR LIST CLICK HERE
D.Yaros
For carburetors manufactured AFTER ABOUT 1935, and a vehicle that is mainly driven at altitudes of sea level to 4000 feet, we suggest the following calibration changes to use ethanol fuel:
   E-10 -lower float levels 1/32 from original specifications, increase main metering circuits fuel flow by 5 percent.
   E-15 - lower float levels 1/32 from specification, increase idle jet flow by 5 percent, increase main metering circuits flow by 10 percent.
   E-85 - nope, not going there at all, good luck to any that try it!
Additionally:  Accelerator pumps with neopreme skirts should be changed to those having leather skirts.  Foam floats should be changed to brass.  Carburetors with vacuum metering systems may need a recalibrated vacuum spring.
Failure to make these changes will cause the engine to run lean.  A lean running engine will run hotter than normal, and this can cause premature failure of valves, warpage or cracking of cylinder heads, exhaust manifolds, etc.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
