Vin # location
Started by Fred Cowin, October 03, 2009, 04:00:24 PM
Fred Cowin
Where isthe Vin number located on the 1958 Deville?
Jeffrey Burland
Hi, The VIN tag is screwed to the B post below the striker plate. If it's missing, it's at the front of the lefthand frame side bar, and on the engine on the center lefthand side of the block above the oil pan. The VIN is the engine number. These are not the same number as on the cowl (trim) tag. HTH, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
Cowin
Quote from: WillingtonCad on October 03, 2009, 04:53:24 PM
Thank you !! This is a great help.    Fred
