1957 Radiator overflow tube
Started by Bill Balkie 24172, October 05, 2009, 08:11:50 PM
Bill Balkie 24172
 Hello , I never had a problem with my radiator or overheating . I noticed my Coolant level was a little low , so i topped it off with Antifreeze . It drank about a quart and a half . A few days later i went  for a ride about ten miles . When i put the car away i noticed the Coolant coming out of the overflow tube onto the Garage floor . I never had this problem before , is it possible  i over filled the radiator. Also i noticed that my overflow tube has a few holes on  the top of the tube . i am not too concerned about that . but i am concerned about the coolant coming out of the overfill tube . Any help would be greatly appreciated  . Also should there be a overflow tank  ?
Bill Balkie
1970 Coupe DeVille
2009 CTS
Otto Skorzeny
First, make sure you have the correct pressure cap and that it's working / sealing properly.
Second, The radiator should only be filled to just cover the cooling tubes.  Check your owner's manual.
The '56 says two inches below the filler neck. More than that and it will pour out the overflow tube when hot.
fward
HUGE VENDOR LIST CLICK HERE
David King (kz78hy)
I think you will be fine.  You probably added to much fluid and it is prefect now since it got rid of any excess.  Not a great way for the environment, but the way it was done in the past.
One more opinion.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
I added a simple radiator overflow to every car I drove not so equipped.  Later I was glad I had.  Bruce Roe CLC # 14630
