1948-49 buick-cadillac X frame,convertible topframe interchange
Started by chas, December 30, 2009, 08:54:42 PM
chas
do the caddys and big buicks share the same body frames and convertible top racks in 48 and 49?
J. Friedman
I'm fairly certain '48 Buicks were different, so whatever body and top parts will interchange with '48 and '49 Cadillac convertibles would only do so from '49 Buicks.
Doug Houston
The '48  Buick still used the 1942-derived "C" body, and the '48 Cadillac used the new "C" body.  There is no similarity between the two bodies.
Further, even year for year, Buick had a totally different frane from Cadillac. Buick had all-coil suspensions, while Cadillac used longitudinal leaf springs in the rear. While Oldsmobile 98 for 1948, had the new "C" body, as did Cadillac, again, their chassis design was totally different. You simply can't scramble parts like bodies and frames......at least with any degree of ease.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
