59 Cadillac - Ignition and Body Locks
Started by Dan Eckstein, March 08, 2010, 12:52:40 PM
Dan Eckstein
Folks,
Does the original ignition lock for a 59 Cadillac De ville have four electrical spades?  Also I am looking for a place that sells these items ignition, door, and trunk locks.
Any help would be appreciated.
Thank you for your time,
Dan Eckstein
CLC #24850
Dan Eckstein
CLC #24850
Dan Eckstein
Cool!  Thanks for the lead.
Ok figured out that there is are two pieces to the ignition switch, a lock cylinder and a ignition switch.  Now my next question, is how do you separate the lock cylinder from the and ignition switch?
Dan Eckstein
CLC #24850
WATCH FOR THE COMMON ISSUE OF THE HARNESS CONNECTOR AT THE IG SW. MELTING, IF SO THAT SECTION OF THE HARNESS MUST BE SPLICED WITH A NEW HARNESS/CONNECTOR. TURN THE KEY CYL TO ACCESSORY, DEPRESS THE SMALL BRASS BUTTON ON THE IGN SW HOUSING, THE CYLINDER SHOULD COME OUT.
