quick, how to drain gas tank
Started by Matt 12861, March 31, 2010, 07:16:23 PM
Matt 12861
Have a non running '99 Deville I want to get 14 gallons gas out of before dark (and put in my '38).  I can't snake a siphon down the inlet.  Anyone know an easy way to do this?
Otto Skorzeny
If it's a plastic gas tank, drill a hole and plug it when you're done.
fward
HUGE VENDOR LIST CLICK HERE
Find a place to break into the fuel line and run the fuel pump.  Perhaps the filter or maybe line running in or out of the fuel rail?  Find the fuel pump relay and you should be able to jumper it to make it run.
LM 25575
Quote from: Otto Skorzeny on March 31, 2010, 07:25:26 PM
And if it is not a plastic one? What about it?
L. Marzana
- 1949 Cadillac 62 4 door
- 1981 HD FLTC
#4
Otto,
Drill a hole?  Put in a plug?  Usually you have good advice, but that's a really bad idea.  Even with a cordless drill, you can have some sparks and you need to catch  the gas in something, it's a messy way to do it.
The fuel pump will not run if the car is not running, so that's not really an option either.  The lack of oil pressure shuts off the voltage to the pump.
You may need to go old school, drop the tank and you need to be very careful dealing with the fuel and the fumes, if working inside.  Extinguish any pilot lights, and keep anything that makes sparks away.
There are baffles in the tank that will make it hard to snake something all the way down, but you should be able to use a siphon pump.  I have a 12V fuel pump with a very long set of hoses and about 15' of wire with clip leads.  When I need to drain a tank, I use some clear hose going into the inlet of the pump and snake it down into the tank.  The hose is long enough to keep the pump, and a 5 gallon can far apart from each other, and away from the battery.  It helps to have an assistant.  If you have enough hose to go from car to car, you will be all set.  I like using clear hose so I can see what is going on.  you can also hear a difference in the sound the pump makes when it is actually moving the fuel.
Don't rush anything that has to do with gasoline.
Good luck,
Glen
76eldo has a lot of good advice.  The pump in the tank is controlled by a relay.  It can be jumpered out.  If you take the fuel line apart at a convenient point such as the fuel filter then jumper out the pump relay the pump will run and eventually drain the tank.  I like the idea of pumping it into another car.
Keep a fire extinguisher handy just in case.
Glen
Glen Houlton CLC #727
CLCMRC benefactor #104
Carfreak
I like the fuel pump suggestion too though I recall reading about plastic gas tanks being drilled to steal the gas when prices were over $4.   Guess we'd have to watch 'Dumbest Criminals' to find out if any of them caught fire.
Thieves Increasingly Drilling Into Fuel Tanks To Steal Gas
May 27, 2008
Dale Fortin is getting a new kind of customer at his Detroit auto repair shop, customers who have not just been in a fender-bender or had a windshield smashed by a rock.  The soaring price of crude oil has turned gas tanks into a cache of valuable booty, and Fortin has replaced several tanks punctured or drilled by thieves thirsting for the nearly $4-a-gallon fuel inside.  "That's the new fad," said the co-owner of Dearborn Auto Tech in Detroit. "I'd never seen it before gas got up this high."
While gas station drive-offs and siphoning are far more common methods of stealing gas, reports of tank and line puncturing are starting to trickle into police departments and repair shops across the country.  Some veteran mechanics and law enforcement officers say it's an unwelcome return of a crime they first saw during the Middle East oil embargo of the early 1970s.  Gasoline prices surged just before the long Memorial Day holiday weekend and crept a hair higher overnight Monday to a new record national average $3.937 for a gallon of regular, according to a survey of stations by AAA and the Oil Price Information Service.
Given their height, Fortin said pickup trucks and sport utility vehicles are more vulnerable to the thieves who puncture the tanks and use a container to catch the fuel.  Plastic tanks are typically the target, he said, since there is less chance of a catastrophic spark, and they are easier to drill into.  A design change may also be contributing to the preference for a drill rather than a syphoning hose. The tanks in many vehicles now have check balls, which prevent spills in a rollover accident. They also make siphoning more difficult.
In recent weeks, police in Denver arrested two suspects in connection with about a dozen cases of damaging tanks and stealing gas.  Denver Police Det. John White sees this "new way of siphoning gas" as a bigger problem.  "What made this particular method so dangerous and concerning for us was the way in which they were doing it _ using cordless drills to puncture holes in these tanks," he said of the rash of cases his department has investigated this spring. "The heat, friction generated could have easily sparked a fire. It just made for a dangerous situation for the suspects and the community."
Tank puncturing has yet to reach the radar screens of law enforcement organizations such as the National Sheriffs' Association, or the Automotive Service Association, a group that represents independent garage operators.  Still, at least one insurance company has taken notice: AAA Mid-Atlantic issued a press release earlier this month that cited a case in April in Bethesda, Md., involving a thief who broke the fuel line underneath a car and sapped five gallons of gas. Montgomery County police said a bus in the same parking lot had 30 gallons of diesel stolen.
"These are crimes of opportunity," said AAA spokeswoman Catherine Rossi. "Right now, some people think that stealing gas is a way to get rich quick. It becomes a question of whether you're leaving yourself open to the possibility that someone can get to your car without being seen."  The cost of replacing a metal tank on passenger vehicles is between $300 and $400, and the plastic tank common on newer vehicles would be at least $500.
Bruce Burnham said thieves have hit the Budget Truck Rental business he owns in Shreveport, La., about a half-dozen times in the past three years. The thefts started shortly after Hurricane Katrina when prices spiked, then stopped for a while, then restarted about a year ago.  In some cases the gas lines have been cut; in others, gas has been pumped out. He figures he's lost at least a few thousand dollars in stolen fuel, repair costs and loss of rental fees.  Burnham said he has taken "extra measures to protect the vehicles," but declined to elaborate.
Gas and diesel aren't the only fuels being plundered. Restaurants from Berkeley, Calif., to Sedgwick, Kan., are reporting thefts of old cooking oil worth thousands of dollars. Cooking oil rustlers refine it into barrels of biofuel in backyard stills. Biodiesel can also be blended with petroleum diesel, and blends of the alternative fuel are now sold at 1,400 gas stations across the country.  Still, the theft of regular unleaded gasoline _ the kind that leaves everyday drivers high and dry _ is on the minds of more law enforcement agencies as prices rise.
Troy Police Lt. Gerry Scherlinck said his suburban Detroit department this month received a report of a stored motor home whose tank was siphoned and drained of 50 gallons of gas. They also had several incidents last year in industrial parks where the gas tanks of vehicles were punctured.  "Gas is liquid gold these days, and has been for the last year-and-a-half," Scherlinck said. "I would anticipate seeing more of these kinds of incidents as the price continues to go up."
Jack Miller CLC# 24441
Quote from: Matt 12861 on March 31, 2010, 07:16:23 PM
I always keep an electric fuel pump around. If you can get a cheap one connect it to your front line (after you disconnect it from your stock pump) and run a line into a fuel carrier.
Make sure that the fuel is not old. Old gas goes bad and can ruin your lines, pump & carb and clog up everything.
