Repairing horns
Started by tom eisner CLC 18396, April 05, 2010, 08:12:32 PM
Is this easily done...... or is it some sort of an art form?
1964 Eldorado
1966 Fleetwood Brougham
1968 Eldorado
1978 Eldorado Custom Biarritz
1985 Seville
1993 Allante
2007 XLR
It's a sickness
Yes, I have done mine, and all it takes is a bit of thought, careful drilling out of the rivets, and replacing same afterwards, separating the parts, and not damaging the paper gaskets, and rectifying the problem with the non-operating.
I found that the careful trimming of the plastic that surrounds the wire coil that is usually out of shape from melting, that stops the "Plunger" from moving backwards and forwards as the current is flowing and stopping works, and also cleaning up the contacts from corrosion.
PS.   Mark the parts in their correct settings before actually separating them.
Mike Josephic CLC #3877
Yes, it can be done -- however, before you resort to tearing them apart and drilling out
the rivets there are a number of easy fixes you should try first.
I'm not going to repeat this all here -- this has been discussed in depth on the Forum before.
Just put "horns" into the search function and read up.
If you can't find it -- let me know.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Guidematic
That's good because the trumpet horn on my '70 stopped working.
The horns are not the same without it.
1970 Fleetwood Brougham 68169
1985 Eldorado Coupe 6EL57
1988 Eldorado Biarritz 6EL57
1994 Fleetwood Brougham 6DW69
