Engine identification-1939 60 Special
Started by Chuck-#21953, May 19, 2010, 07:11:05 PM
Chuck-#21953
I've located the following numbers on the left rear of the engine block:
                         8F34542     and
                          *83540*4*
What do I have here?  Am I tanked?
Jim Stamper
     I think tank numbers are on the right front.
Jeff Hansen
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
As Jim said Chuck, I too always thought the tank engines were stamped front right, all three engines I have are, guess some early production ones may have slipped the net.
Doug Houston
It ain't a tank engine. It's a 1941 engine from a series 62 car.
The alpha-numeric number is the engin e unit number, which has letter "F"in it, so it's a '41. The engine number is for a series 62 car.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
