1956 Intake Manifold Help
Started by okccadman, June 22, 2010, 10:25:29 PM
okccadman
My 56 has a cracked intake.  I have a 55 and a 58 laying around.  Will these interchange?  If so, what are the differences?
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
okccadman
The carbs are different sizes on the 58 but I can use it if i need to
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
90 Brougham
92 Fleetwood Coupe
93 Allante
Pat
OK,
I think the ports are smaller on the 55...I would go with the 58.
Cheers,Pat
J. Gomez
Jim,
The 1958 should be a direct bolt on intake; however as you stated the carb base plate is different.
If the crack can be easily reach why not fix it, low heat welding or strong epoxy welding should do it? Just a thought..!
Good luck..!
J. Gomez
CLC #23082
okccadman
I wasn'y aware it wa spossible to repair one of these.  It is cracked right by one of teh bolt holes on teh passenger side.
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
90 Brougham
92 Fleetwood Coupe
93 Allante
J. Gomez
Jim,
Yeap, I beat you it is at either #4 or #6 intake..!
Heat is not much of a concern for the intake as it is for the exhaust manifold. If it just a crack around the tab it is possible to use a low heat rods and weld the area, or possible use an epoxy. There are several companies that sell special low heat rod to weld several types of metals including cast iron, or you could try a local welder that tackles cast iron.
A machine shop could also perform the repairs if they have the tools, you would also need to make sure the surfaces are straight as possible before installing it, 25’lb is not much torque but if the intake is warp these tabs are prone to crack.
Other members may have alternative solution..!
Good luck..!
J. Gomez
CLC #23082
