1961 Cadillac Heat-Defrost Control Cable Installation
Started by Jack Miller CLC# 24441, July 30, 2010, 06:21:33 AM
Hi All,
When I put my dash back together, I don't remember the correct way that all of the cables go. The service manual doesn't help.
I am not getting heat or cool  when I move the bottom lever and the upper lever for defrost & heat is wrong too.
I think that the cables in the heater box and on the switch are also wrong........................................Help please!
Jack Miller
1961 Cadillac
Dan LeBlanc
Jack.  If I recall correctly, the upper cable goes into the heater box and the lower goes on the front of the heater box.  There is an adjustment to them, however outlined in the shop manual.
Dan LeBlanc
