Seatbelt Retractor Cover Replacement, '68 Eldorado
Started by Perry, December 12, 2010, 05:43:14 PM
Perry
Please help!  Trying to figure out how to install a new seatbelt retractor cover on my '68 Eldo.  The blade at the end of the belt is too wide to go through the slot in the new cover, so figuring its the other end, that gets wound up, that must go through the cover first then reassembled to the retractor assembly?  I just don't see an obvious way to get that all apart, haven't faced this before, and looking for some guidance before I break something else.  Pics attached....am I right that this has to come apart?  How so?
Thanks!
Perry
Tim Groves (Cadillac Tim)
I believe the latch was stitched on after the plastic cover was slid over the belt.  I've never been able to get a replacement cover on without making a small cut in the opening so the latch can slip through.  Tim
Perry Bush
Thanks, Tim - yep, that occurred to me and was hoping to avoid cutting the nice new cover.   I wondered if the black end cap on the reel might come off somehow allowing the spool to be separated from the belt?  That way, non-latch end of the belt might come through the cover slot?   Anyone ever try this?
Perry Bush
CLC # 24801
Anything is possible, but when removing the cover, take care that the spring doesn't suddenly unwind itself and cause you an injury.
From "playing" with various Seat Belts, there could be a shaft inside the central post that simply slips out to allow the "loop" to come out.
