1953 Hydramatic - Will it fit other years?
Started by Jeffrey Burland, December 26, 2010, 03:01:17 PM
Jeffrey Burland
Is there anything specific about a '53 Hydramatic (not dynaflow) that is specific to '53 or will it work for other year Cads without modification? thanks, Jeff. Just asking for a reference.
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
PHIL WHYTE CLC 14192
The torus cover to flywheel bolts are not the same as the 54 and 55 Hydramatics. The bellhousing on the 55 engine will not mate with the cover on the 53. It wont fit 56 onwards.
Phil
Doug Houston
What the above message says is that the bell housing for the car you want to use it on must be the one you use for a '53 H-M transmission. There is a '41 Cadillac in this area with a '54 transmission in it, and it works. I have driven it.
When a change is made, be sure to use the selector lever and the TV lever from the car you're installing the transmission into.
My own preference for pre-52 Cdillacs (Pontiac and Oldsmobiles) is '46 thru '51 Hydra-Matics. Those were  the lst models to mach the 41-51 selector quadrants.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
