1959 Cadillac - Steering Pump Whine
Started by Dan Eckstein, July 15, 2011, 09:52:51 PM
Dan Eckstein
I am restoring a 1959 Cadillac and I have a steering pump whine.  I have not had the steering pump rebuilt and do not know if it had worked before.  What I noticed is the steering pump works fine when cold but after I drive the car for 15 mins the steering pump begins to whine.  I have checked the fluid and it is full.  Not sure how to fix it.  Any thought would be appreciated.
Thank you for your time,
Dan Eckstein
CLC #24850
The pump on my '56 did the same years ago. It was disturbing, but I did nothing. I have the impression that the noise disappears with the time.
Roger
Dan Eckstein
How hard is it to rebuild a steering pump?  Do you need any special tools or press?
Dan Eckstein
CLC #24850
walt chomosh #23510
Dan,
  My 1955CDV power steering pump started to whine so I bought some additive which cured the noise for a while.....so,when the whine returned, a trip to NAPA resulted in a power steering pump seal purchase.(it was the only part in their listing for my model year) I don't recall any special tools required for teardown/assembly,but I do remember clocking of parts as being critical. Problem solved(noise gone) 4-5 years ago!(my car is a driver)The seal was cheap and was all that I needed other then a couple of gaskets(resovoir to housing) which I made....walt..tulsa,ok
Dan Eckstein
Thanks Walt!  I think I will attempt to replace the seals and see how that goes.  Appreciate the responses!
Dan Eckstein
CLC #24850
