1928 341-A V 8 Electrical Question
Started by kenscaddie, July 25, 2011, 08:52:39 AM
kenscaddie
I am about to start the rewiring of my 1928 341-A 7 Seater.
I do not have an Electrolock, and was wondering if this will cause too much of problem re getting power to the distrubutor.
Is there a work around ?
Is there anyone over in the USA that is or can manufacture an Electrolock?
Aside from the 6 Volt issue, and turn signals are there any other pitfalls or things that I should be aware of ?
Also I will be installing a 6 Volt electric fuel pump between the tank and the carby, about mid way along the line.
This unit will run at very low pressure, just enough to keep the vacuum tank happy.
Are there any issues in fitting one of these ?
Thanks for your assistance.
Ken Andersen # 21420
Wayne Womble 12210
The electrolock is just a simple switch as far as the electronics is concerned.  Any switch will work in place of that. I think there is someone on this forum that has a couple for sale.
Don Boshara #594
Ken,
Let me know if you need a wiring diagram.
1940 Sixty Special
1966 Mustang Cpe
kenscaddie
Hi Wayne,
Thanks for your response.
Hopefully that person will see the post and contact me.
Regards
Ken
Hi Don,
Thanks for the offer of a wiring diagram.
I have the basic diagram that is obtainable from the 1928/1929 Worshop Manual.
Is the one that you have any different ?  If so, can you drop me a copy at:  kenscaddie@bigpond.com.
Thanks and Regards
Ken
Wayne Womble 12210
Sorry they are 30-31 over in the for sale section.  I am not sure they are the same for 28.
