INSTALLED AIR LEVEL SHOCKS ON MY 78 CADILLAC
Started by R Schroeder, September 15, 2011, 11:21:11 AM
Maybe they just had a bunch of them laying around the warehouse.
R Schroeder
cadillactim
I got that big spring in the adapter kit for my 95 Fleetwood, and the instructions said it is a replacement spring that goes in the black filter on the air compressor itself (where the air line attaches to the compressor).  You unscrew the big cap and replace the existing spring.  I didn't switch it out, but I think it helps regulate pressure to the rear shocks.
Tim Groves
R Schroeder
#23
See, I knew there was an answer. I didn't get any directions with my kit, although they said on the front of the package to read all directions.
That's why I couldn't see where that went.
Roy
Just went down and looked at rhe manual. I see where it goes and what it does now.
Think I'll go out and put it in.
Thanks again.
Few hours later :
I looked at the spring that was in the unit, and the replacement spring. New one was much shorter and a lot harder to push, so I left the original factory spring in there.
So the spring fits inside that little plastic air tank looking thing?   I thought that was a dryer?  And it didnt come apart?
R Schroeder
T.J.
The tank has a end on it that screws off. At the bottom is the dryer, then the spring goes in.
The spring pushes dryer to hold it in , and on a flat plate  in cover,  that maintains 8 to 15 pounds of pressure.
You have to hold the tank and then unscrew the cover. If you try to unscrew the cover the tank will just turn.
Roy
