53 water pump disassembly
Started by Series 75, November 16, 2011, 08:24:36 PM
Series 75
hello all!  I recently purchased a 58 Cadillac with no motor or trans. I have a lead on the block with no accessories. I bought a water pump from a junk yard, it came off of a 53 Cadillac limo with a 331. the problem I'm having now is getting the pulley off and the internal blades, so I can clean out the rust from inside. Is there a way to remove the pulley and internal fan part?
