hood removal 1941 cadillac
Started by mr41cadillac, March 06, 2012, 08:19:21 AM
mr41cadillac
can anyone advise the best way to remove the hood  from a 41 series 60 special thanks john m
Its been 9 years since my 41 but I seem to remember you undo the bolts attaching it to the hinge mechanism just under the back edge and lift it leaving the hinge and cross bracket in place.
mr41cadillac
thanks i see where to do it looks easy
Jeff Maltby 4194
I drilled a small hole in each hinge through the hood bracket to properly align it with a finish nail after hood install.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
mr41cadillac
thanks to s. passmore very easy to remove
