Where does this go?
Started by KD, May 28, 2012, 01:17:48 PM
KD
Does anyone know where this goes? I didn't remove it , it was in a pile of the car parts. It looks like it goes somewhere on the frame or underneath somewhere. It's for my 1940 9033
KD cls#26801
Ken Dennison
1935 Auburn S/C Cabroilet
1940 Cadillac V16 7 passenger Imperial Sedan (9033)
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
This is one of several "Splash Pans" that fit around the engine at the oil pan to chassis  level,
KD
Ken Dennison
Not really as I dont have a model the same as yours but you usually have one on each side of the engine utilizing some of the pan bolts and a series of small bolts into the underside of the chassis. On my car theres a split pan just like the picture with that small bracket to span the exhaust. Get under there and see if they fit anywhere, a bit of trial and error.
Brad Ipsen CLC #737
Left side inner fender.  The small holes on the right side of the picture were for rivets to hole the rubber splash shield that goes around the shock.  The big holes where for hex head (3/8") sheet metal screws with big washers that go into sets in the fender.  This is not exactly the same has 38 and 39 which I am very familiar with but there may have been changes made for 40.  If not it might be for big series V-8 in 39 or 40.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
KD
Thanks, Brad.The fenders are off and I didn't look under them to see if it went there
Ken D
Ken Dennison
