41 60 special gas feed
Started by mr41cadillac, June 07, 2012, 03:00:10 PM
mr41cadillac
still trying to figure out gas feed from firewall to carb . where does the spring go. this is a manual transmission thanks john
Bill Ingler #7799
Please look at attached pictures which should answer your question. The front of the spring attaches to the carb as pictured and the other end attaches to a hole in a small arm that is attached to the bolt holding the cross over exhaust.
mr41cadillac
thanks bill i fixed it right thanks for taking those pictures worth a thousand words john
