Cad 1941 Series 62 Conv. Coupe -Courtesy Lights location
Started by gigipeters, July 03, 2012, 05:16:17 PM
gigipeters
Hello,  Does anyone know exactly where the courtesy lights  should be located in the inside of a 1941 Cadillac Series 62 Conv. Coupe? (the ones that shine down on the floor area when you open the door).  I found 3 stored in the glove box but I'm not  sure if they are placed under the dash or in the kick panels, etc.?
Thank you.  J Smith, #27287
Doug Houston
Without going downstairs and double checking, the only interior light on those bodies is the light on the rearmost top bow (the wooden one. Thi light operates from the door jamb switch (or switches), and the slide switch on the driver side rear interior panel.
There are no under dash or lights on the rear seat base.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Bob Hoffmann CLC#96
Doug is correct. If you'll post pics of the lights you have, maybe we can ID them. Also, I like to get all the info from your data plate located near the LH hood hinge. I'm compiling  a roster of existing 41 conv. cars. Thanks, Bob
