Brake Fluid '39 LaSalle
Started by JohnWNY, June 25, 2012, 10:52:32 AM
JohnWNY
Is DOT 3 still the best brake fluid to use for the orginal breaks on the 1939 LaSalle?
Dot 4 maybe more desirable as it absorbs less moisture than dot 3.
Mike Josephic CLC #3877
Agree with Dave, use DOT 4.  It has a higher temperature rating, absorbs
less water and does not have all of the associated hassel of switching to DOT
5 (silicone).  With silicone, you have to change out the whole system or risk
having leaks everywhere you have a rubber gasket / seal.
DOT is now more or less obsolete.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
