'53 Dome Light
Started by broadcreek, September 08, 2012, 01:43:30 PM
broadcreek
I have no voltage to the dome light. I can not figure out where the wire comes from going to the light; and the shop manual is not helpful. Any one have an idea?
If it is a CDV it comes from the switch in the back seat of the car, I believe on the drivers side. it does not go on when you open the door. The folks in the back seat turn it on and off.
John Washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Philippe M. Ruel
On sedans it comes from the switch on rear door pillar, driver's side.
1952 60 Special in France.
broadcreek
This is a 62 series coupe. There are no other switches except for the one at the dome light itself. The wiring is faded so it's difficult to get any color code from it to trace. Is it possible to rotate the main light switch (on the dash) to activate current to the dome light?
