41 model 6227D
Started by Joe Bergeson, December 29, 2012, 03:04:54 PM
Joe Bergeson
Can someone tell me what the woodgrain is called on the dash and moldings for the 41 6227D?  I have seen a number of different examples and not sure which is correct.  Thanks,
Joe B
Joe B
kkarrer
Joe,
    I believe the finish on mine is called "burl walnut."
Ken Karrer 1941 6227D coupe
Joe Bergeson
Joe B
936CD69
Confirming Ken, the 41 data book says "burled walnut grained" instrument panel
Craig Brillhart CLC# 26217
1993 Sedan deVille Spring Edition Carmine Red White Top-SOLD!
1993 Sedan deVille Spring Edition Triple Black
CLCMRC Benefactor #302
Joe Bergeson
Thanks guys!  Appreciate your help.
Joe B
Joe B
Doug Houston
In most places, the wood grain has (incorrectly) been called Walnut.
The manufacturer of the original graining pocess (Di-NOC) called it  Burl Carpathian elm. It is walnut color, and to get the refinishgraining materials, you might have to go with the "walnut" description.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
