1941 Cadillac Front Grille
Started by flw004, January 02, 2013, 08:10:09 PM
flw004
Can't seem to find a decent grille anywhere for my 1941.  Looks like I'll need to repair the cracks in the current grille.  Anyone know of a welder in the Los Angeles area that welds and polishes pot metal/cast iron grilles?
Thanks, Fritz
CLC 22666
1941 Toure Sedan
1960 Coupe De ville
1965 Coupe De ville
1976 Eldorado
Doug Houston
There should be quite a few grilles that an be re-plated without welding them. They are a great big die casting, and often are found with cracks, but there should be some in sme members' parts stashes that can be re=plated. It won't be cheap, but at least, you won't need to do weld repair.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
flw004
Thanks Doug, I've put the word out, still no response.
Doug Houston
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Paul Phillips
Fritz
Do a search on a product called Muggy Weld.  I have used this to repair several pot metal cracks with good success.  Otherwise, I will have a spare 41 grille, getting ready to choose which core I am going to replate, then the other will be available.  PM me if you don't work something out with
Doug.
Paul
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
