1939 60 Special rear axle seal.
Started by Thad, February 02, 2013, 03:00:33 PM
Thad
I have to change out the rear axle bearing and seal on my 1939 60 Special.  As I understand it, I have to pull the rear axle to do this.  What holds the axle in place?  Do I have to go into the differential to free it?
Charles A. McMillen--#21953
Nothing holds it in the diff, remove the brake plate and bearing cover then pull the axle out with the bearing and seal. A slide hammer usually does it.
Bill Ingler #7799
This PDF file of an exploded view of the rear brake drum might help. Use a press to remove and install the axle bearing. Do not use a hammer and punch to remove the bearing as one slip with the punch can damage the axle surface under the seal and cause an oil leak.    Bill
