Posting pics from a MAC (continued from Cant post pics topic)
Started by VooDoo, July 24, 2013, 11:58:45 AM
VooDoo
I am trying to post some pics along with my comments and it sends me this:
I am able to attach them and everything but when I hit the post button it send me to a blank page.
They are about 800kb each which is under the max limit. I've posted much smaller pics in the past with no problem so I know I am following the correct steps. I am kinda at a loss.  Thanks
This is the page I'm sent to after I post and it's blank
http://forums.cadillaclasalleclub.org/index.php?action=post2;start=0;board=1
Andy Fulenwider
1937 75 Series Convertible
1947 62 Series Custom Project
J. Gomez
Andy,
I'm using a MacPro w/Safari as the default browser, I'll try to attached a picture and see if I have the same results as you.
OK Update it works on my side.  ;)
What browser you have? Have you try emptying the browser cache, that may help.
J. Gomez
CLC #23082
Chris Conklin
I am also a Mac user with Safari. It seems like a size issue, how many pics are you trying to load? Even if you're under the size limit but you exceed the number of pics it won't post.
Chris Conklin
