1960 Cruise control FITS?
Started by 60eldo, July 23, 2013, 12:31:54 PM
60eldo
  Wondering if a cruise control unit from a 60 will fit a 1961  62?  They look the same
Jon. Kluczynski
quadfins
The CC motor and unit will interchange. The mounting is similar on '60 & '61 - above the driver side exhaust manifold - which also means that the throttle connection rod, etc should also interchange. '62 units mounted onto the inner fender, but that location can be easily used, too. The unit itself did not change
The main difference will be in the interior switch and throttle adjustment cable. Each year, '60, '61, & '62 changed. But if you have a donor car and all the parts, it can be done. I did it.
What, specifically, is your intended plan?
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
60eldo
   Im helping a friend, he wants to know if a cc unit from a 60 will fit properly in a 61 or 62,,thanks
Jon. Kluczynski
