58 horn wire wire advice
Started by Rimsvet, August 01, 2013, 07:24:20 PM
Rimsvet
Hello group. Rather newbie here and am getting a little time to address some issues on my 58. Has anyone has to reattach the a horn wire that disconnected in the base of the column. Doesn't look like an easy fix in the car. Do I need to remove the column? If so, never done that before, what am I up against? Thanks for the help. From what I've read on a few threads you seem like a fun bunch.
Bryan
58 coupe deVille
Bath, Pa
Bryan Rimbey
58 Coupe deVille
Bath, PA
Buster Miller
Its not to bad of a job, you will have to remove the column and the Neutral safety switch!! There's a very helpful article about the 57-58 horns in the last issue of the self starter written by Peach State CLC President Doug Bailey!!
