Which headlamp is OEM (if either) and where do I find another one?
Started by MB49Caddy, July 26, 2013, 12:30:01 AM
MB49Caddy
The Numbers on my '49 sedan headlamps read as follows:
Drivers side: "2" (at top center of lens)
Passenger side: "2D1" (at top center of lens) & "WAGNER" in center of lens
Also, how do I remove these to replace once I find the OEM ones?
MB
"Sir, my concern is not whether God is on our side; my greatest concern is to be on God's side, for God is always right." - Abraham Lincoln
harry s
Matt, The original headlights on your car were Guide metal reflector type seal beam. They are almost impossible to find and very expensive if you do. A vendor at Hershey a couple of years ago had a limited supply at $135 (or so) each. You can get later Guide 2 beam bulbs which are still pricey compared to aftermarket replacements such as Wagner, GE, etc. How's everything else coming with your '49?    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
MB49Caddy
Thanks, and I may have found some!  ;)
Everything else is going ok with it, but a lot of work to do on it.
Fixed the leaking window piston in the drivers door and I think we have the leak stopped from the rear diff, but time will tell as I saw a few drops today in the driveway but not sure where that is coming from yet.
Other than that it is a blast. Love the car!
MB
Alan Harris CLC#1513
If you really want to be excruciatingly correct, you want six volt Guide Headlamps without the aiming lugs on them. I think the lugs came along in 1958 or so.
Jeff Maltby 4194
#4
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
That gives me the thought- I wonder if these have been reproduced by the Corvette guys?
MB49Caddy
MB49Caddy
From another CLC'er...
Recognize these as OEM for my '49?
MB
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
That link was very informative. If the literal correct lights aren't available, I wouldn't bother with reproductions of the replacement ones. AACA judging standards only require that the lights be a matching pair. That seems reasonable to me.
