1956 hood hinge springs
Started by Matt 12861, September 12, 2013, 08:02:27 PM
Matt 12861
My winter project is working on a 1956 hearse (S&S) I got about ten years ago.  I bought it and stored it, now I am starting on it.  The hood won't stay up, there are no springs on the hinges!  Can anyone with the master parts book tell me what all years and makes and models might fit?  I am going to the Canfield (Ohio) swap meet tomorrow and need to be on the look out for them.
Matt Givler
Matt Givler #12861
jeremy9146
Hey Matt.  Congrats on finally having the time to start your newest project!!  As far as I know I believe the hood springs from 54 through 56 should be the same.  I'm not positive however I'm pretty sure.  Hope this helps and good luck tomorrow on your treasure hunt!!
Jeremy Weiss
Jeremy Weiss Bridgewater, NJ
Current collection of Cadillac’s
1953 Eldorado
1959 Eldorado Biarritz
Bob Hoffmann CLC#96
#2
Matt,
My 1966 MPB shows the 56 as one year only. 54/55 are the same. The 56 spring is a lot cheaper than the 54/55's. Maybe someone has some first hand experience. Maybe Cad Cliff has some real 56's.
HTH, Bob
54 & 55 hood hinges are totally different than the '56 ones. This is the reason why the springs were cheaper for 1956. Have a look in a shop manual for 1954 and 1956 to understand. Sorry, I'm away from home and cannot show a picture.
J. Gomez
Matt,
As Bob and Roger stated the 1956 hood spring is a one year only per the MPL. The 1964 MPL shows the part # for them under Group 8.013 -> http://www.modifiedcadillac.org/documents/Shop_Manuals_and_Illus_Catalogs/Master%20Parts%20List%20thru%201964/Group%208/tn/Group%208%20-%2015.jpg.html
The spring measures approximately 6” in length with 1 ½” OD and 0.24” spring thickness. You may find an equivalent one from other GM models.
The 1956 Chevy “looks” similar, the picture is just for reference. Although the Chevy hood is lighter it may not provide the necessary tension for the heavier Cadillac hood.
Good luck..!
J. Gomez
CLC #23082
