Installing 1955 reproduction rubber splash apron/sheilds
Started by 5390john, October 30, 2017, 11:05:56 PM
5390john
Hey out there in Caddy cyberspace.........
Need help to figure out how to install inner front fender rubber splash shields sourced from Rubber the Right Way. See attached, there are no instructions with the kit. There are 6 pcs to the kit, 3 pcs are used inside each front fender. The longest piece goes over the top A-arm with the long section pointing to the front of the car. The other two are what I need help with.
Anybody out there have photos or input on where these go and how they are oriented?
To quote Leia......"Help me Obi-Wan, you are my only hope"
John Adams
1955 CDV "Marilyn"
"Panic Accordingly"
Bob Kielar
Hope these pictures will help. I know when I did my 55 I could not figure out two of them in the kit and put them on the shelf. I used heavy staples and the original holes.
Keep Cruzin,
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
55 cadi
Rubber the right way has good tech support, they can sent you email of how most goes, or talk you through it, but those may be made by Steele rubber and they have great customer service also, just call them  you will get help also, most of what rubber the right way has is from Steele rubber
Jason
1955 Cadillac sedan series 62
1966 mustang convertible w/pony PAC, now in Sweden
2005 Cadillac deville
5390john
Bob:
THANK YOU for the going to the trouble of taking those great photos. Very Helpful.
John Adams
1955 CDV "Marilyn"
"Panic Accordingly"
Caddy Wizard
Here is one image I found that might be of some help...
Art Gardner
1958 Eldo Seville (2/3 done)
5390john
Hi Art:
This is also very helpful, thank you!!
John Adams
1955 CDV "Marilyn"
"Panic Accordingly"
