41-60S Tail light
Started by Terry Wenger, May 07, 2014, 09:05:12 AM
Terry Wenger
I have noticed several 41 Sixty-Specials over the years, including my own, with a crooked right rear taillight apparently because the hole in the fender was stamped wrong. Has anyone else seen this or have any knowledge about this?
Terry Wenger
Terry Wenger CLC #1800
tewv16@sbcglobal.net
1932 355B TSD
1939 7557
1940 60S
1941 60S
1947 6267 Conv.
1949 6207X Coupe
1963 60S
harry s
Terry, I have noticed that also but it was usually on a restored car and I just attributed it to the re assembly process. I wonder how much trouble it would be to try and correct that.    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Barry M Wheeler #2189
Terry, this was first noted some thirty-forty years ago in the S/S. The conclusion was that it was a production glitch and not worth fixing, probably knowing that the fender would not be used again in 1942 production.
If a customer noted the problem, a valid assumption may have been to give the buyer an allowance on his next car. Or free oil changes while he had the car. Whatever.
With your fantastic memory, I'm surprised that you didn't remember this. Of course, this was in your "Ignore the '41s as everyone has one" stage of collecting.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Terry Wenger
Barry:
I first saw the problem about 40 years ago, But I would say it was discussed in the S/S before I joined, because it wasn't in the S/S since Jan. '68, my first issue. I have often wondered about it, but as I was doing bodywork on my 41-60S a month ago, I was looking for it.
To fix it, I had to move (rotate) the tail light about 3/4 of an inch at the top of the lense to the right to make it vertical. The fin needs to be moved also.
Thanks for answering that question !
Terry Wenger
1932 355B TSD
1939 7557
1940 60S
1941 60S
1947 6267 Conv.
1949 6207X Coupe
1963 60S
