1953-1954 Power steering
Started by jyinger, April 09, 2014, 12:28:59 PM
jyinger
Are the steering column and gear box from a 1954 interchangeable with a 1953?
Jon Yinger
CLC#26643
Jon Yinger
I doubt as the 1954 cars are from another Generation than the '53 models.
Jon,
I believe that 1954 was the first year when the assembly was no longer one piece and you could take the gear out without removing the steering column. I believe 1953 is by itself, for 1952 they recommend in the Serviceman to use the new 1953 gear.
jw
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
jyinger
Is the drag linkage the same for '53 and '54 cars with power steering?
Jon Yinger
CLC# 26643
Jon Yinger
The steering drag link has a specific part number from 1950 to 1953; 1954 has another part number. 1955 and '56 has again another part number. Don't ask for the differences between them, I don't know.
