1968 Eldorado Rochester Carburator question
Started by IcebearLars, January 08, 2015, 04:41:24 PM
Roy,
My apologies, I learned it wrong years ago, red circled item is vacuum breaker, not pull off.  Overall, would consider this a learning post -thanks.
R Schroeder
Scot, I have made MANY more mistakes than you, but we all learn from them.
Roy
cadillacmike68
Quote from: Julien Abrahams on January 10, 2015, 01:07:57 PM
I was just wondering if anybody has ever tried whether it makes any difference with regard to performance (or lack thereof) if you disconnect the vacuum dashpot that control the opening of the secondary air valves. A couple of months ago I was playing around with my carb (and an annoying vacuum leak), and just to see if it made any difference, I disconnected the vacuum dash pot that controls the opening rate of the secondary air valve. To me it appeared to make no difference at all.
If you are referring to the green circled item above, that has Nothing to do with opening the secondaries.
"Cadillac" Mike
Julien Abrahams
No, I know :). I was referrnig to the red circled vacuum pull off. I thought that I read in the shop manual that this slows down the opening of the secondary air valve if you would floor the throttle to prevent a lack of fuel. This would make sense as it is directly connected to the air valve.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
R Schroeder
See reply #19.
There also is a lock out tab , off the choke linkage , that will prevent the secondary's from opening until the choke is fully open.
How fast the secondary upper butterfly opens depends on the number of turns , for tension , on the spring itself.
But the front vacuum break is just for a lock out.
Roy
