pull cable above ignition switch 41 60 special
Started by mr41cadillac, January 04, 2015, 03:51:52 PM
mr41cadillac
how does this cable fasten to shaft of carburetor ? DOES THE CABLE CLAMP SOMEWHERE /? IS THIS A MANUAL CHOKE THANKS JOHN
joeceretti
I believe it is a throttle cable.... I am 100% positive no manual choke should be on your car, when original.
I had to go through quite an ordeal to get my manual throttle mechanism working. Still don't have the correct cable but it all works as it should.
Joe is right, Its not a choke but a fast idle cable and attaches to a lever on the opposite side of the carb to the throttle linkage, thats if you have the original carb, many were swapped out for later carbs that never had this feature or the levers fell off.
mr41cadillac
its there with the lever but i cant get it it move shaft, does the cable clamp down somewhere thanks john
joeceretti
#4
Do you know which carb you have on the car now? If it's like the 38, the manual throttle is on the other side, as Steve said, and is directly connected to the same axle as the pedal throttle which also has the throttle plates.
Pictures of your carb will help us help you a whole bunch.
mr41cadillac
i know that. im trying to see if the cable clamps down somewhere, as the clamp on the shaft wont turn the throttle shaft
joeceretti
The throttle shaft should be directly connected... one solid shaft. I can't picture it.. as if one side won't turn the other side surely will not. I can't reconcile it... pictures :) please.
Bill Ingler #7799
#7
John: The cable is not clamped and goes up from where it is attached to the front of the dash and comes out on the engine side of the firewall as shown in the picture below. Then down and under the crossover exhaust and connected to the carb. If the pull wire inside the cable is not moving, then take out the cable and hang it up so that when you squirt some 10-40 on the inside wire and loosen the rust, the 10-40 will eventually come out the other end. I had the same thing happen when I got my 41.   Bill
Bill Ingler #7799
John: I might have read your problem wrong. Take a look at picture below at 3 and 4 arrow. The pull wire in the manual throttle cable is attached to an arm which is clamped to the end of the throttle shaft by a small set screw. If the pull wire in the throttle cable moves and the set screw is tight holding the arm on the throttle shaft, then the throttle shaft should move giving an increase in engine RPMs.   Bill
Bill Ingler #7799
Wrong picture above      I hope this is the correct picture below
mr41cadillac
thanks.  i think i had my clamp positioned the wrong way or  down where i see yours is up. also i have a screw and bolt instead of a set screw so i dont thing the arm is holding , its just turning aroun the shaft. but the cable  works, its to late tonight but tomorrow i will fix, it but i think the issue is the slipping, thanks john
Bill Ingler #7799
John; The more I look at the screw holding the arm on the shaft it looks like a screw going through the clamp and a nut on the bottom side. Somebody with a 41, please post as to if there is a nut on the bottom or just a set screw holding the clamp tight on the throttle shaft. Thanks  Bill
On all of mine is a screw with a square type nut on the bottom that prevents it from turning so one can tighten it using one hand.
mr41cadillac
yes mine has a screw with what lookes like a square wood screw that fits in a groove that prevents it from turning. maybe i just didnt tighten enough. will look at it this pm. thanks
mr41cadillac
thanks all i fixed it. the pictures you sent showed me mine was upside down lever backwards and nut on wrong side, no way  it could make shaft go the correct way. now it works, thanks john
