1959 Rear floor pans, are the four doors the same as the two doors?
Started by Sean Roe, February 01, 2015, 07:21:11 PM
Sean Roe
Hi All,
I have a 1959 Series 62 4 window that needs floor pans in both front and rear.
Does anyone know if coupe rear pans will also fit the four door?
I looked at OPGI and C2 fabrication, but neither call out that the rear pans offered also fit the four door.
Any help would be appreciated.
Sean
Quentin Hall
Buy the 59 60 Chev pans that are stamped as per factory. They are the same as Cadillac and all other GM for those years. Cadillac had longer extension just behind front seat but that is just a flat strip. Cadillac has bigger Trans hump but that won't be a problem for you.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Sean Roe
