1966 Eldorado Cruise Control Repair
Started by jadob, March 08, 2015, 02:59:20 PM
jadob
Hello Board;
Been away from the board for awhile.  I am trying to get all the odds and ends repaired on my Eldorado.  The other day I took it out for a short drive and found that the cruise control is working, but not a the correct setting on the dial.  It apparently thinks 75mph on the dial is an actual 55mph on the road.  I thought something was wrong with the car at first when It started to rattle and shake just to get to 55 then I realized the cruise control was on.  Does anyone know a repair person in the greater Los Angeles area?  If so could pass the info along.
Thanks.
JD
