Trailer hitch for 1947 model?
Started by MartinC, March 17, 2015, 03:33:28 PM
MartinC
Hello,
Looking for links, photo's, & advice. I need a rear hitch on my '47 60S. It only needs to tow a very lightweight trailer.
Are they available? I would have thought a home-made could be made to fit the bumper mountings.
MartinC
I've just discovered those type that clamp onto the bumper, never seen them before!
WHat sort of weight will they take?
Bill Ingler #7799
In the late 40s I remember my father wanting to haul a small car on a trailer behind a 48 Olds. The hitch was designed so that the pulling part of the hitch was tied into the rear axle and the tongue weight of the trailer, including the ball, was bolted to the rear cross member of the frame. I would not want to use a hitch that only clamps to the rear bumper as I would be concerned with pulling as well as trailer tongue weight causing bending of the bumper. I would think that any hitch you used today for your 47 Cadillac would need to be custom fabricated.  Make sure your old car insurance is still valid with towing a trailer.    Bill
Sweetsally
Quote from: MartinC on March 17, 2015, 03:33:28 PM
Hello,
I don't think they make a hitch specifically for your vehicle. I think you might need to either fabricate one or get someone else to do it. If you know someone who welds you could always get a hitch box and weld that on. I found a link to a website that carries them called Hitchweb: http://www.hitchweb.com/category/TA-B-3-1/Receiver-Extensions
The other thing you might be able to do is to get a bumper hitch. Hitchweb also carries these hitches: http://www.hitchweb.com/category/TA-B-3-8/Bumper-Hitches
Hope this helps!
Smedly
I would be interested in a pic as well. I eventually want to pull a small trailer for my Harley behind my 46.
When a Doctor "saves a Life" it does not necessarily mean that that life will ever be the same as it was, but he still saved it. My 46 may not be as it was but it is still alive.
Sheldon Hay
Quote from: Smedly on March 21, 2015, 09:18:04 AM
It's not what I would say a very lightweight trailer!
Smedly
I did not say very light< I said small >:D It would be around 1200lbs. with very minimal tough weight maybe 50-75lbs.
Sheldon Hay
